Brief Description: Transponder back shell installation...
I had forgotten to install the the transponder connector back shell on initial installation. I removed all the connector pins again, slid on the back shell, repinned the connector and secured the back shell. Then I turned to the glareshield, compass and map light dimmer installation. I wired the power, ground, transponder and reostat dimmer wires.
Garmin GTX-330 Transponder back shell installed
Glareshield, map and compass lights dimmer wiring started
